IR modes?
Can someone explain how the new modes in the IR engine work and when to use them? I used to use multiframe incremental to save out my IR maps but now I see there are two new ones called Animation (prepass) and Animation (Rendering). So which ones should I use and what are the benifits? I’ve also read that now you can calculate the IR map over a network, how is this done?
They’re for rendering animations with moving objects.
So if there are no moving objects just stick with multiframe incremental?
Edit:
What about rendering out the IR map over a network, what’s the process there?
Keep in mind that with V-Ray 1.5 final , you can even render IR maps with DR (concerning animations).
nikki Candelero
Can DR be used with more than 10 CPU’s?
10 cpu’s per license
Right but what if I have 3 licenses, can I use 30 buckets?
Yes, if your network can handle it and if your os can maintain the required number of connections. Also to clarify it is “per node” not cpu or cores.
One more question about the Amimation (rendering) mode, I understand that using Animation (prepass) will create a seperate .vrmap for every frame but once I switch to Animation (rendering) mode how do I load all of these maps into it? I can only select 1 .vrmap at a time, there doesen’t seem to be a way to select all of them.
I need to know this aswell.
Do they need to be merged in the irmap viewer?
yeah you just select the first IR in the sequence, and vray will do the rest. You dont need to merge them either.
V-Ray will locate the sequence of IRMap files, and will know exactly how and when to load them. If you have played with these new features, you should have noticed, that V-Ray sets a sufix after the name you give for the IR map, which is actually a number pointing the frame number of the animation sequence.
nikki Candelero
I’ve messed with this feature and it is really great! I notice that when you enable the rendering preset, it has the Intrp frames available. I understand what it does, but what’s the advantage/disadvantage of having it interpolate more (or less) than 2 frames forward and back? :wink:
Where do you see this, I can’t find it?
Edit: never mind I see it, it’s just grayed out because I’m using medium-animation. I’m assuming you still set how many nth frames you want to calculate right?
Well I’ve gotten no where with these new modes, when I calculate the animation (prepass) of every 15th frame I get a series of .vrmap files in my network folder. When I switch the mode to animation (rendering) and pick the first file in the sequence and send the job to Backburner most of my machines say they can’t load the IR map, but some do render. The machines that render either aren’t reading the IR maps generated by the prepass or the maps that were generated are messed up in some way. I must be stupid because I can’t figure out how this thing works for the life of me. Isn’t there some kind of help file or tutorial on how this process is supposed to work? Those of you that say you have had success can you please give me and explanation on your process so I can see where I’m going wrong.
My understanding is that if you are doing it for animation you need to do it for everyframe, and every 15th frame will not suffice.
Unfortunately I haven’t gotten a response back from Chaos to get my dongle licensing upgaded, so I can’t test it yet.
That makes since, I’ll give it a try.
Yeah you must render every frame, its not like when doing a static scene, u need to give Vray every frame to interpolate itself.
Do I have to do this on my main machine or can I let the network render it out?
Network rendering works.
