i am about to render some high res stills of a large exterior development.
proberly a2 output.
can anyone offer any advice on the minimun sizes of irradiance maps for high res stills.
thanks
Tony MacDonald
proberly a2 output.
thanks
Tony MacDonald
hi
well i normally render the irr map out at half the size of the output save it and then render the full size version from the saved map.. just turn up the AA a little more.
regards
dude, every time you double your output resolution you can effectively reduce your irradiance map min/max settings by 1.
see this link http://vray.info/entry.asp?entryID=101 for further clarification.
Justin
Thanks guys!
