I am working on a render and noticed there is an issue with mirror reflections.
- The ceiling paint color is not correctly rendered (it’s off white)
- Same as above.
- The recessed light above the tub looks more dispersed in reflection than actual.
What could be the possible reasons? Is this something fixable?
Hi @nvangamudi ,
shading in mirror reflections is more simplified (due to performance reasons), which means that only direct light (+ambient term) is considered and no indirect light. Since the ceiling is shaded with indirect lighting (global illumination) when viewed directly it happens that there’s a slight difference in color. So I’m afraid this is not unexpected behaviour and if it’s distracting for your screenshot I’d suggest to either post-process the area or select a view with less obvious differences in shading of the reflections.
Hope that helps
