Issues turning off "Generate GI" on objects
I’m not sure if I’m doing something wrong, but I’m trying to remove the GI bounce from this one object (Box) onto the floor, but disabling “Generate GI” in the object’s V-ray properties doesn’t seem to have any effect (see attached screenshot).
I’ve even tried disabling “Receive GI” in the V-ray properties of the ground plane in combination with the above, and it doesn’t change anything.
The only thing that seems to work is disabling GI globally (which I don’t want to do).
Am I missing something?
This is in Max 2026.3 and V-Ray GPU 7, update 2 hotfix 2, and occurs when using either Brute Force or Light cache GI.
Max File
lol, I think I may have quickly solved my own question: Do V-ray properties only work with the non-GPU version of V-Ray?
It seems to be behaving as expected there.
It’s not supported. The issue is logged as (VGPU-2381). I’ll add a bump on your behalf. The simplest workaround is to use a VRayOverrideMtl, where the GI material has pure black diffuse/opacity.
