Standalone render without Global Illumination
Hi, we are trying to render vrscenes exported from 3dsmax on our vray (maya) standalone linux farm.
But we cannot find a way to disable Global Illumination with the vrscene exporter within 3dsmax. It always renders with Global Illumination.
Best Regards,
Robbert
Is this on any scene? Which V-Ray version?
We are using 3dsmax 2015 with Vray 3.10.03 and V-Ray Standalone version 3.15.01
Here’s a sample of the first lines of our vrscene.
For some reason it does not pick the regular render settings but the RT settings, which I cannot find a option to disable GI:
// Exported by V-Ray Plugins Exporter
// V-Ray core version is 3.10.03 built at Jan 10 20:39:20 2015
// Exported at Mon Feb 16 17:51:57 2015
// Frame at time 0
SettingsRTEngine rtEngine_settings {
trace_depth=5;
gi_depth=3;
cpu_bundle_size=192;
cpu_samples_per_pixel=8;
gpu_bundle_size=192;
gpu_samples_per_pixel=8;
coherent_tracing=0;
stereo_mode=0;
stereo_eye_distance=6.5;
stereo_focus=2;
opencl_texsize=512;
opencl_resizeTextures=1;
opencl_textureFormat=2;
progressive_samples_per_pixel=1;
undersampling=0;
disable_render_elements=1;
max_render_time=0;
max_sample_level=0;
noise_threshold=0;
enable_mask=0;
max_draw_interval=150;
min_draw_interval=50;
Make sure that Engine Type is set to CPU from V-Ray RT settings, and GI is off from Vray Adv settings:
V-Ray always uses GI if RT Engine is Cuda or OpenCL, that’s why the exported scene is with enabled GI even if it is disabled from V-Ray ADV options.
You can enable/disable GI on already exported vrscenes from the following command:
Thank you, I’m going to try this out! :slight_smile:
