Before Corona 10, I seemed to be able to have CoronaAO components upstream or downstream of MappingRandomizers and Triplanars, but in 10, CoronaAO’s are not behaving correctly for me when they are upstream. Is this expected behavior?
For example, this is the result when I have the following material setup…Checker map>CoronaAO (w/ a red occluded color)>Mapping Randomizer>CoronaTriplanar. Is the Mapping Randomizer acting on the upstream Corona AO component? If so, I don’t think that was the case in previous versions.
edit: after a little more research, it looks like it behaves correctly in the CoronaAO is placed between the Mapping Randomizer and CoronaTriplanar…you just can’t put it upstream of both.
