Issues with Corona 15 and tiling assembly via deadline
We are having an issue with Corona 15.2 and tiled rendering via deadline. The issue that the tiled main pass gets written with the same output name by each worker rendering separate tiles, then upon assembly deadline can not locate the individual tiles. The syntax that the main pass writes out as doesn’t follow the typical suffix for tiled output.
All of the render elements write out correctly and assemble correctly.
If we turn off corona frame buffer in the corona system settings and go back to standard frame buffer this issue doesn’t occur and the main pass tiles write correctly - and then assemble.
We would prefer to be able to see the Corona VFB on the worker so we can see the element and also stop a render midway, get the denoising and get the output, something we cant do with the standard max VFB.
Any ideas?
Hello, thank you for your report. We already have this logged under an internal ID (CMAX-2501). We will let you know once there are any details available as to when it will be fixed.
Thanks Marcin, Ill await your reply.
