image compression makes it hard to distinguish if it’s rendering noise or shader… But I guess it is combination of noise and the image compression itself amirite? Maybe some close up view could tell more…
The preview in my original post up top had some grain from:
a. I didn’t let it fully clear as it was just a quick test render.
b. Some of the post work added a bit of noise as well.
Add to that the image compression as you guys mentioned and it looks pretty rough. The original render wasn’t bad, but here’s an updated version that I let run for an hour while I was at lunch. NOTE: I added some post work tweaks here too so it has more punch than the original render.
Any tips for tinted glass? When I tint the thin glass it seems to become far too reflective. I could give the windows some thickness and go with a full solid glass with a thin absorption amount but figured thin glass would be faster/easier.
Awww really? I thought it went pretty well with the pearl white exterior. What color/material would you recommend for the interior?
I remember there was a bug in thin glass I reported a while ago ( super bright reflections ). It has been fixed in the nightly builds.
I’m sure Ondra can hook you up with Nightly builds
This would result in too brigt interior. The tint has to be either set in refraction color slot, or just use solid geometry + solid refraction + attenuation. It should not take too much time, as long as you dont use any small light sources.
Indeed, going the route of giving thickness to the glass and using a solid glass configuration seems to work better in this case. I do think I ran into that bug you guys were referring to though where the glass reflection became overly bright.
For alpha software it’s great. Seems very stable, super easy to use, pretty good feature set for alpha, and fast/efficient at CPU rendering.
I’m keeping my fingers crossed in hopes that it stays that way as more features are implemented. I’ve been down this alpha/beta road several times before with applications that were super fast only to become bloated and slow in the actual release.
If the developers can keep it on the current track where it’s light, fast, easy to use, and efficient for v.1 then they will have a winner.
Don’t worry, apart from SSS+Media support/some fakes/better caching, the shading core is almost done, and the speed/ease of use did not significantly change in the last year and a half (if anything, it got better ;))
