i just recently discovered corona - thanks to lasse - quite a nice render engine with some potentials. did my first test today with an simple scene made in vray. I used the material and light converter script from the forum and hit render.
I’m quite satisfied with the result for no effort. Hope to find time exploring the engine and the settings in depth.
Seems very slow for such powerful CPU, 2678 is more powerful than 3930k (which achieves over 5mil/s rays). Can you run the benchmark which is on this forum ?
What settings did you run this on ? Default PT+PT ?
1): you won’t have a valid comparison unless you use Bf+LC in Vray and Pt+HDCache in Corona, but that just as a sidenote
2): The converter script will not make “good” materials. You still have to make sure that your window glass is set to thin or hybrid mode (depends if it’s just a polygon or a box with thickness). That can make a huge impact.
3): You can try to use portals unless you would need lots of them. Keymaster told me that there is a usable limit until those portals will work with embree acceleration.
just figured, that there is a big discrepancy between Ray/s in benchmark and when rendering from within 3dsmax
benchmark i got nearly 6million rays/s while when using hd-cache or pathtracing in 3dsmax its around 1.2 million
