i keep losing the vray licence then have to keep restarting max.
I get the same on a dell xps 720 - try using a different usb port on your computer and see if it helps.
Which V-Ray version are you using? Also is your license server running on the same machine?
Anyways, there are two things to try: you can try restarting the license server or move the dongle to a different USB port and see if it helps.
and you don’t need to restart max, you just need to close/reopen the render dialog
I am using v-ray adv 1.50 sp3a.
Yes the license server is running on the same systtem.
I keep losing the license when i cancel the rendering during lc calculation.
Ok then; can you email me to vlado@chaosgroup.com; I’ll explain how to obtain the log information from the license server, which hopefully will give us some more info about the problem.
maybe you have the same problem as I had and I solved it.
I had the VRay dongle put into the usb port of my dell monitor and each time I turned off the monitor and came back after some time, the licence could not be found and rendering had crashed.
The problem is: turning off the monitor also turns off the usb port of the monitor and this makes VRay loose its licence. :roll:
Maybe this helps you or someone else. Would be great to have a fix for that, because I only have those two usb ports free at the front of my dell precision t7400
and the dongle is stickung out and this sucks… ![]()
