Keyframe at the same Timestamp
Hi. My problem : I want to create a 5 second pause in the video. I have 2 keyframe at the same Timestamp but I can’t change the time of this keyframe. If I change the time of the first, the second changes and vice versa. Have you an idea ?
Hey @Remy_1 , thanks a lot for your post and welcome to our Forum.
In order to create pauses in your videos, you’ll have to also create a very small camera adjustment (in any direction really) for each keyframe so they are not seen as the same - even the slightest of movement is enough, which should also not be really visible during your pause either.
I hope this helps! If you’re unsuccessful, please let me know too.
Thanks for your answer.
I find a solution to my problem.
I modify directly the xml file of the path and it’s working.
Best regards
