For the overlapping, thanks for discovering that. I had totally forgotten I have adaptive grid turned on. In hindsight, it’s not a very good idea if the simulator should not overlap. It’s difficult to measure because they expand over time. I will need to redo the sim with adaptive off.
Oh, with ocean sims, adaptive grid can easily lead to bad results, it’s surprising that it did the job for you. I was thinking about adding a warning message for such cases.
Yeah, now that you mention it… I turned it on because i was trying to experiment with having it being adaptive and resizing appropriately to reduce cell count, but clearly I did not think that through. I lucked out. A warning message would be good to have/including this info in the documentation for adaptive grid section.
The oceanpriority setting would be nice to be included in the doc as well. I had trouble grasping it because while it’s mentioned, it does not mention that it’s a feature in Phoenix 4.40, nor does it explain that higher number means higher priority. My first instinct would be like backburner priority where higher number means less priority, or like tyflow, where you have evaluation priority and 1 means it will be evaluated before 2. Maybe a more technical mind would understand it immediately, but not me haha.
But kudos to you guys for helping. That was a smooth and reactive support. Cheers.
