Never really sure what category to put these sorts of posts into: is it a ‘General’ post, or an ‘Off Topic’ post??? Who knows?
Anyway…
I still struggle with creating very realistic, luxury carpet materials in my scene. Rugs I also struggle with, but for the purpose of this thread, I’m looking for suggestions on creating a wall-to-wall carpet (in a bedroom for example). The sort of look I am going for is this:-
Ideally, procedural would be good, as large, non-tiling bitmaps I see as being tricky to acquire, but I am open to suggestions. Would you use bump, vrayfur, displacement? Where a chair leg or a bed leg hits the carpet is another area that gives away a rendering as being unreal, but to begin with, suggestions on creating this sort of look would be appreciated. I’m guessing it has a lot to do with varying a soft reflection over the surface, which is broken up by the pile being pushed around by footprints, vacuum cleaner marks etc.
EDIT: here’s another example of the kind of luxurious, deep piled carpet I am aiming for:-
you could try with either a strand or a small crop of strands scattered over a surface ans see if it works. rotation of the strands could be driven by a bitmap to simulate footsteps and whatnot. this way it should look good even if looked at close distance, certainly better than a 2d texture.
I think bertrand benoit has some rug strands already modelled that he shares on his blog..
looks good to me. how are you going about it, is it displaced?
did a quick test with the scattered geometry approach, I reckon one can get decent results, even though it may be not that practical in your scene. and I’d say your carpet is already coming along nicely.
here’s what I got so far in case you’re interested:
Its quite complex actually - it started off being quite simple but then there were several noise/falloffs/blends etc. I also have a little bit of displacement in there. Its a 3.5MB zip file if anyone wants it. If you can improve on it, let me know…
(If I had the skills to be able to paint a matte where all furniture legs touch the carpet (within the viewport) I guess that could somehow drive the depth of the displacement, making it look depressed slightly. Not sure how to do that though.)
I’ve uploaded the zip file in my post above. Have a go with it and see if it works. I’d be interested to know how scene specific it is. One area that was annoying me was a sharp looking edge in the wider shot. Not really sure where that is coming from.
can you not use a VrayDistanceTex map to drive the displacement for the furniture? (you can add the relevant objects that you want to depress the carpet)
