Latest VRay Builds updated
Hi all
I see from the support section that the latest official build is 1.5SP1, however there are demo versions of newer builds. Also Vlado often mentions that they working on a specific feature and that it will be in the next build or that feature so and so was included in such and such a build.
Is there some kind of secret support section I dont know about or does Vlado just send some users a link to newer builds since they need a feature that is not in the official “latest” build of 1.5SP1?
How does all this work? If I’m starting a new project, what is the latest VRay version I can use for it? I mean if I request it, can I get a newer build than the official one? I’m a bit lost
Kind Regards,
Morne
Use the official - latest stable build. I think the demo’s have watermarks and besides they are just that … demo’s, problems might come up using them.
Normally what happens is if you’ve got something horribly wrong with vray for what you’re doing at the time Vlado will give you a version with a fix but without comprehensive testing it’s impossible to say if that fix has a knock on effect or not - For this reason it’s generally a bad idea to stray away from the main release builds - These ones tend to have been hammered in testing so you can rely on them a lot. It’s normally a bad idea to continually use the latest untested build since if you return to an old project at some stage a newer build might give you different issues or render with slight colour and lighting differences, hence why the latest development build isn’t automatically released - it’d be far more problematic than it’s worth.
Sounds like SP2 may be out soon anyways :slight_smile:
If you have a show-stopping problem that can not be worked around and you email me to vlado@chaosgroup.com, I could provide you with a fix (if it can be fixed, of course); however as others pointed out, internal builds are somewhat of a work in progress and are not fully tested.
Also, SP2 will be released soon (sometime around the release of 3ds Max 2009).
Hmm SP2 sounds good. I think I understand now. 1.5SP1 is the latest stable build and is the one I should be using. If only my dongle will arrive I can get away from RC5! (its been only 2 weeks so I’m geussing I’ll be waiting another 2 weeks - I hope not longer than that)
That’s it and thankfully rc5 is a really good build - there’s very few things it can’t do in any production situation. Coupled with having backup if there’s any serious issues it’s a greta situation to be in.
Where can one read up on the fixes\additions in SP2?
Hello
Where can I get version 1.49 R5??
Is there any link in the site for getting older versions?
I want this because I’m using 1.50SP1 and I get the feeling that theres some slowness in “processing vertices…” when using proxies and just want to test it.
Its about 30.500 proxies of 6 objects with about 20.000 triangles.
It hangs in there for a little over a minute and then begins updating instances.
I have works on scenes with more than 100.000 trees with 10 instances of about 100.000 triangles each and I don’t remenber that big pause before the “update instances”
Is this normal?
what ive my show stopping problem is that im feeling anxiety and inferior without sp2. would that be enough for me to get a copy? hehe
I share your anxiety Da_elf!
“newness withdrawal syndrome”…
I usualy satisfy my addiction by downloading daily builds of SourceForge projects.
Quoted for Agreement: RC5 is one of the best recent builds to produce with.
It may not have all the latest bells and whistles, and a few, minor bugs, but boy that works great.
Would anyone care to post a link to RC5? I’d like to try it out…
Unfortunately RC5 is no longer officially available, unless there are specific circumstances that prevent you from running newer builds.
Please change the subject of this thread it is misleading!!!
i second that hhee
how do I change that?
SP2. :slight_smile:
What will be include in SP2? only bug fixes or there is something more… :slight_smile:
the cool render button !!!
