As the topic say… sometimes after working in a scene for a while the objects go invisible when I blend two materials with the layered material
Anybody else having this?
What kind of materials are you making? Can you share some images?
I have attached a scene with a cube
For me, when I open the file the cube is visible. It have a layered material on
Take the png I have also attached, when I place that in the layered material mask the cube goes invisible.
Would be good to know if it is my system or something in c4d/ corona?
I had the same issue two days ago.
Corona 4 DailyBuild Feb 20 2019
would anybody please be able to test this? I would like to bug it if needed, if it is only my PC I would love to know what is causing it…drivers?
I cannot use anything layered at the moment…
i have the same problem too
Thanks!
@Beanzvision, can you move this thread to the bug list or should I open a new one?
Sure thing. I have also tested your scene and can confirm this. Adding to our bu reports. ![]()
Thanks for moving it.
Yes, very inconsistent. I tried layered materials a few times, always work, stop, work, stop… that is why I was hesitant to report it earlier. But lately I need them more and more so it got frustrating ![]()
Thanks for testing!
No problem at all, thanks for bringing it up! ![]()
