leather 70s chair
unfortunately I don’t have the file at hand at the moment (it’s on a backup drive which is out of our network), so I can’t show you any screenshot of the mat.
off the top of my head I don’t remember the exact settings, but I think it was a vray blend mat with very strong, rough fresnel reflections. I used a hand painted specular map in the falloff’s “side” slot, and pretty much no bump at all.
the coat level was probably just a hint, it had the same spec map but it was a bit more glossy. I guess.
to me the key for these kind of shots it’s you lock the camera first, and then you start tweaking your material’s reflections and maps strength and whatnot after that. going from a camera position to another may need different tweaks, so I very seldom consider a material done just looking at it in the mat editor.
so I guess at the end of the day it really depends on your specific scenes and setups, but I’ll definitely post some settings when I can open the file again :slight_smile:
and again: really exellent!!
Cool. Thats given me something to start from. Would be great to see some settings…really appreciate that :slight_smile:
Wow
Beautiful!
again, thanks for all your comments :slight_smile: I didn’t forget about the screenshots, guess I will get to it in the week end.
well, it’s been a while but eventually I got the file back. and it turned out the material it’s much simpler than I remembered: no blend, no diffuse, no bump.. just a specular map and glossy reflections (0,72 in this case).
here’s a screengrab:
and the map looks like this:
and you keep hearing people saying you have to fiddle with a bunch of sliders and buttons to get what you need out of vray :slight_smile:
Cool. thanks for the info. I’ll give that method a try on my chair :slight_smile:
Thanks again
