Ho do we enable the lens effects?
In the panel accessed through the V-Ray frame buffer, I get the warning “No channel, please prerender!”
The topic on Lens effects in the help is referring to the way in works in Max I think.
Thanks,
-Marc
Thanks,
-Marc
Hi Marc,
In VFB,you enable the lens effect by ticking the 2 boxes (glare and bloom),then do a render,then you can adjust the effects.
Renée
Hi Renée,
Does it mean I first have to make a render to have acces to these controls, tick the 2 boxes and then hit render again?
you can bring up the vfb by clicking the F button in the V-Ray toolbar.
No you don’t have to do a render,just open the vfb like Devin said
Ok, thanks.
I did not tried it because in VfR 1.05 it was not possible to open a frame buffer window without doing a render first.
Thanks!
