License Status 64
New monthly customer,but can’t acived the license, license status =64.
Hi @xwtao , please make sure that you didn’t exceed the number of activations for your license - unfortunately, this error code can also indicate that the maximum amount of seats has been reached.
If that’s not the case, it could indeed mean that Enscape could not connect to our licensing server to verify the status of your license.
Provided that you’ve had access to the internet at the time this issue occurred, I assume that you probably connect to the internet via a proxy server?
In that case, you’ll might need to configure your proxy settings. You can do that in Enscape by clicking the [About] button in the Enscape ribbon → [Configure Proxy].
Please ask your administrator what to fill into these fields.
If, however, you’re not connected to a proxy server, another possibility is that your firewall is blocking Enscape from connecting to our licensing server. In that case, I’d ask you to create an exception for the address ‘http://licensing.inreal-tech.com’. The port is ‘80’.
Please contact us via ‘Feedback’ button if the issue continues to persist!
Thank you, I’ll try to figure out this issue.
I’ll hit into this topic just to ask one quick question. I hope Shaun won’t mind that :slight_smile:
Will I be able to install Enscape with a student license on another computer (when I finally buy one…) if I start using the license on my current notebook?
I have an university project that needs to be done immediately and Enscape would be really helpful right now but I wouldn’t like to lose an opportunity to use it when I switch PCs…
Hi @Areczan ,
sure, no problem. You can always revoke your student license (or any fixed-seat license) from one computer in the [About] window → [Remove License]. After that you’re free to reapply your license to any other machine.
Hi @Kaj_Burival_1 ,
I dont know about Revok, so i reset my pc Without revoking License, Now, in same computer it is showing like in image, What to do now?
@Sivaram_Madhavarapu , could you please give me the e-mail address which was used in the purchasing process of Enscape? Should you be a student (and you own a student license instead), could you please send me your license key via PM so I can reset the activations? :slight_smile:
please help my to revoke my license because i forget revoke when i reset my windows now i can’t use my new license thanks
@yudisthira , as mentioned in my reply to your PM, please be so very kind as to send me the license itself, or the e-mail which was used to acquire Enscape so that I can look up the license key and reset its activations. :wink:
I reset Windows without revoking license. Please help me reset its activations. My e-mail is . Thanks
@hoaibao20 I cannot find a license connected to that e-mail address. Could you please check back for the address you’ve used to request Enscape?
PS: I’d recommend you to not post your personal mail address in public spaces. It’s better to send in a ticket to .
hola con todos tengo el problema de que no puedo activar una nueva licencia que tengo para el programa, debido a este error.
@Joel_Guerra , as mentioned in the conversation you’ve created, I’ve sent you a PM with short instructions. :slight_smile: You generally just have to send me either your e-mail address which has been used to acquire Enscape, or the license key itself. Either one via PM please for security/privacy reasons! :wink:
Hi. I am also experiencing the same problem with my license. I recently had to reset my computer and now, I cannot use my license. I need to have this fixed as soon as possible.
Sent you a PM as well. :slight_smile:
same problem , but i can solve this problem when you go to activate. you must check the dialog box , Used system default.
see this picture to solve it.
Can anyone please help me, I am not sure what the issue is, but whenever I try to activate my Enscape, it just keeps saying the same error message.
"New License status = 64
Your license could not be activated probably because you’ve exceeded the number of seats for your license. You can try to revoke your license in the “About” panel on your other machine. If you need further assistance please do not hesitate to contact the Enscape support via the feedback button!"
I applied for the student version of Enscape, can I also get a pm?
I have also sent you a PM to resolve this. Since your e-mail / license key will be shared with us, we don’t want to discuss this openly in the forum. :slight_smile: Also, welcome to our forum!
I am having the same problem:
I am a student and I have used an educational license key previously on my computer, but had to reset my computer without cancelling my license for enscape. I requested a new educational license key which was sent to my email and when i go to apply my license key I get the error seen in the attachment.
Why can I not apply my license key and how can this be fixed?
Hola, acabo de restaurar mi computadora debido a un problema y ahora me aparece el error que esta en la imagen. Me podrían ayudar estoy usando la licencia de estudiante para usar el programa, les agradecería su ayuda.
