Licensing issues - wibu key and Windows 8.1
I’m trying to renew my educaitonal license of vray for skp, but myself and the reseller have hit an issue with getting my existing wibu-key to work.
I have installed the Vray License server on both my older Windoes 7 machine, and my new Windows 8.1 machine. I have downloaded the latest drivers from the Wibu website, for 64 bit. However, when i insert the wibu key, only the windows 7 machine recognises and installs the drivers. I am using the USB 2.0 port on both machines. Without this, I cannot get another license/run the license server.
I know the educational license isn’t a big sale, but hoping I can find some resolution regardless.
Has anyone else has issues with Windows 8.1 and their Wibu dongle?
Please, contact support@chaosgroup.com for this matter. They are the expert in licensing issues.
I had several problems to install VfS due to operating system 32/64 bit releases. Have you tried to install 64bit wibu driver? Find your driver for 64bit at http://www.wibu.com/downloads-user-software.html
Like I said in the original post, yes I have.
This has been placed in the “too hard” basket. Have changed to a different renderer for now. Will revisit soon when I have a spare hour!
I’m sorry, it’s true. I didn’t read correctly your post. I have W8.1 and W7 on two machines like you and I’ve got no problem with “old” dongles and new license server (using USB 2.0 or 3.0). And I helped to install many times this software to my customers both educational and adv licenses on Mac and PC.
When you had an hour :wink: you can try to reinstall from the beggining.
If you have the same behaviour you can check this:
Maybe user rights issue? Do services (license server and wibu) start properly? Do you see wibukey server icon on tray? If so, red or green?
