I’ve got a model that has been rendering fine up until I imported a few stock models, now the light cache gets to about 95% and hangs for ages (not sure if it even completes as I’m up against a deadline and keep trying new things).
An override material fixes the issue, so I assume it’s a material issue. All Materials are VRay, I’ve run a script to check and convert any that aren’t. I can’t think of what else might be causing it within a material?
Yeah, as soon as I swapped the Blend materials out for the VRayBlend it was fine.
A “debug” mode, or similar would be so useful for situations like this. I have tried changing the log level to 4 but there is simply too much to trawl through.
