Light limitations
Is there a way or guide to know the light limitations for escape on the rhino?
I found out that spotlights have a cone angle limit, 50 or something like that is the maximum value, even if you try to increase the angle this doesn’t work, also if you try to modify the cone angle height these won’t work
In the case of the linear light I know that the limit is 3 meters in length
Rectangular lights also have some issues, but it’s hard to figure out what the maximum dimension is for these lights.
How can we know the exact parameters for lighting?
