Light Link Problem with Shadow.
Dear Chaos Group Support Team,
There is a shadow problem with Light link.
Please check below image. There is a shadow even if I disconect pShere1 with vRayLightRect1.
Is it normal for V-Ray or is there any solution for this issue?
Thank you for your help.
Best Regards,
Sangho Jung.
This is currently a limitation, which will be resolved eventually when we rework the way light linking is handled in V-Ray. For the moment, you can use the V-Ray override attributes to assign a perfectly transparent material to be used for shadows for that object. However this will affect all lights, not just a particular one.
Thank you very much Vlado.
I really appreciate it for your help.
