Light Material: direct and GI emission control
Hi all,
I’m looking for a node setup to use the Light material without emission of GI.
I come from Vray43dsmax and with 3dsmax you can go to “object properties” and disable the GI emission.
Here I tried to use the Wrapper material and the Override material without luck.
How should I do?
thanks in advance
I’m really a noob…
I’ve found the same 3dsmax “object properties” in the object panel…
Solved!
