Light Not Lighting Scene
In my scene I use a VRay dome light for the main scene lighting, but within an enclosed area I need to create some additional lighting. I have been able to do this by using a standard omni light, but I cannot get the additional lighting to work with using either a VRay sphere or 2nd dome light. Each time it renders as if it is turned off. What am I missing here?
thx
What kind of camera are you using? If its the V-Ray physical camera I would start by lowering the shutter speed and see if that helps. Can you post a screenshot of the light and camera settings?
I’m just using the standard 3ds max camera.
try decrease your shadow bias see whether it help or not
DomeLight won’t illuminate the enclosed scene unless the enclosed objects is excluded from shadow casting.
V-Ray lights placed inside the enclosed volume should affect the rendering however.
Would it be possible to attach a simplified version of the scene for investigation?
I was able to figure this out finally… it appears that something went wrong when the light was created. I think it was originally created as a plane light then later switched to sphere. I deleted it and re-created the light and it’s working as expected.
Glad to hear you sorted it out.
Let us know if it happens again.
