light set up
Hey guys
I’m trying to set up a light tent so that I can render cutlery sets, but the wood base is never crisp and always blurry, could some one help me out?
The wood material is just the Wood_03 that comes with Vray.
the wood looks like this…
and its not crisp!
this is the 3dm file
Any help will be much appreciated!
Re: light set up
The problem is that the resolution of wood texture is too small. You have to find a better texture. Also the Image sampling method that you are using doesn’t help. You are using Adaptive Subdivs and your material is a glossy material. For glossy material is better to use the Adaptive DMC.
Best
Re: light set up
ok cheers its looking bit better got to just edit the lights ad setup till its right.
