Lighting analysis for illuminance not working
I have an issue seeing the lighting analysis for illuminance from Vray for rhino. I put an IES light on top of a cube in the model just for testing. The function works fine when I switch to luminance but not illuminance. The issue is for both grid and false colors.
Please see the images below. Is this a setting issue or Vray issue?
If you are using the GPU render engine, please note that the Lighting Analysis render element is currently not supported. If you open the V-Ray Progress window (bottom-right button in the VFB), you will see a warning message for any unsupported features.
Are there plans for the future to support the illuminace caculation with the GPU render engine as well?
Since the lumince calculation works alright with the GPU render engine.
-oconv
@oconv
It is on our roadmap and the Lighting Analysis render element will be fully supported by the GPU engine in a future release.
