Lighting during daytime
Sorry, I could not find this in a short moment, but, during daytime I want to have a look from the outside to a building wich has a rather dark room → so I thought I place a light (omni) in that room, but I know that Enscape doesn’t work with lights during daytime 'cause the sun should overall have extreme brightness, I understand, but how do I deal with such situation - I want to lighten up the room anyway.
Tnx!
Hi @RemcoNL_1 ,
Simply adjust the brightness of your light to be actually visible during daytime. If you tell me what CAD software you are using, I can tell you how to adjust the brightness of your light.
Hello Kaj, I use Revit 2019, tnx!
Alright, then:
  • Select your light fixture family
  • Click [Edit Type] in the Properties window
  • Scroll down to “Photometrics”
  • Select a higher Initial Intensity.
Feel free to try higher values, at some point you will see your light :slight_smile:
Additionally to that, you can also go to the Enscape settings and increase the “Artificial Light Brightness” slider. It’s in the “Advanced” settings tab in Enscape 2.5, and in the “Atmosphere” settings tab in the 2.6 preview.
Let me know in case there’s further questions.
