Lights issues with GPU. Vray 7.10
In this sample render, as you can see below, there is a strange whitened rectangle when I render with GPU. But when I render with the exact same parameters with CPU, that strange rectangle is not there.
Wondering what can be causing the problem with the GPU renderer.
Not sure what can be the issue here, it would be best to send us the scene for troubleshooting via :https://support.chaos.com/hc/en-us/requests/new
Hello @tashko.zashev
Here is more info.
I’ve done a very simple render with Sketchup including this lamp from Chaos Cosmos library (called Limbus Chandelier more specifically)
This is the result with GPU
This is the result with CPU
Same parameters and everything.
This is the Sketchup file with the asset
https://f003.backblazeb2.com/file/wordpress-videos/wp-videos/2025/09/example.skp
But given that it is in the Chaos Cosmos library, I think it’s pretty straightforward to reproduce this GPU bug.
Thank you! It is reproducible and will log this to our bug tracker.
