I run both Max 2021 and 2018, when installing Vantage I select all boxes and it shows up nicely in Max 2021.
It does not show up in Max 2018. Am I doing something wrong? (Vray 5.0 on both as well.)
To be honest: I don’t even know for sure if 2018 is supported.
Thanks for letting me know! (If there is a manual work around, perhaps by moving some plug-in files from 2021 to 2018, please let me know as well.)
Have a nice weekend!
Hi Yard2380,
The installer only supports and detects 3Ds Max 2021, 2020, 2019. You could manually copy the following file:
[LIST]
[*]%localappdata%\Autodesk\3dsMax\2021 - 64bit\ENU\usermacros
[LIST]
[*]Chaos_Vantage-UtilityFunctions.ms
[*]Chaos_Vantage-VantageImportChanges.mcr
[*]Chaos_Vantage-VantageLiveLink.mcr
[*]Chaos_Vantage-VantageTransferAnimVrscene.mcr
[*]Chaos_Vantage-VantageTransferStaticVrscene.mcr
[/LIST]
[*]%localappdata%\Autodesk\3dsMax\2021 - 64bit\ENU\usericons
[LIST]
[/LIST]
[/LIST]
and paste them accordingly to:
[LIST]
[*]%localappdata%\Autodesk\3dsMax\2018 - 64bit\ENU\usermacros
[*]%localappdata%\Autodesk\3dsMax\2018 - 64bit\ENU\usericons
[/LIST]
That should make them appear in Max 2018.
Alexander
Thank you very much, this works!
I am having a trouble getting the Livelink buttons to show up at all. We tried the process listed above with no success. Any chance there’s something we are missing?
Max 20 vray 5
In V-Ray 5 update 1 the Vantage toolbar is part of the V-Ray for 3ds Max installation and as far as I know it doesn’t have the issue which started this thread.
Do you have the update ?
Greetings,
Vladimir Nedev
Installing the latest Vray5 worked. Thank you.
