Not Vray related but.. have anyone lost the XYZ handle in MAX? It’s gone, resetting, restarting and loading default UI configs don’t work!
Can’t move anything in locked axes now!
?? :shock:
?? :shock:
try hitting the x button. and this is the wrong forum for non vray related issues.
I know and that wont work. It’s actually completely gone :shock:
Pressing down the + key don’t work either, in case I rested on the – key by mistake and shrinked it to oblivion.
is ‘use transform gizmo’ ticked in preferences ?
delete or rename your 3dsmax.ini in the root folder and restart !!
(if you have a customized ui.. you should save it before doing this step)
dennis is right. Switch on the transform gizmo in your preferences. ![]()
