Hi guys,
I’m not sure if this is the right place to write about this.
Is there a way to save LUT directly from VFB?
Thank you in advance
LK
Hi guys,
LK
Yes, you can save a .cube LUT from the button “Globals…” above the Exposure slider. Click it and then click on “Save”. Then from the dropdown of the window choose .cube instead of .vccglb.
Yes you’re right…
What I mean is to save the end result after the LUT is applied (as final render).
Right now it saves (bakes) all the effects except the LUT.
Oh, I see what I mean now. No, as far as I know this is not possible. What if you stack both LUTs on top of each other in post? I think that should work. ![]()
Yes there are many ways I guess.. in post.
Not sure how hard it is to bring it to VFB, it would be a very nice feature to have.
Thank you Alex_M
You can simply copy (Ctrl+C) the image from vfb with all the effects. ![]()
Yup, I know that…
but lets say you need to save 6 different shots and send them as a folder to the client..
how do you manage to do that without a 3dpart app?
