Maps don't display in material preview when map channel ≠1
Hi guys,
Not sure if known, but coronabitmap doesn’t show the map at all in the material preview if you’re using anything other than map channel 1 - it just displays the diffuse colour. It works fine in max bitmap. Can this be looked into?
Cheers,
Hi Alex,
Thanks for reporting this. I can confirm it behaves like this, I will report it to the dev team.
Cheers,
Rowan
p.s. I PM’d you regarding an old issue with ForestPack, would you have a chance to take a look at it?
(Internal ID=425816287)
Cool. Yep got that request. Will look into it as soon as I have some time.
