Here is an (ugly - sorry :-)) image for a feature that has been requested a lot and is coming the next build… 1000 animated characters with unique geometry and motion blur, done with animated VRayProxy objects (more than 27,000,000 triangles):
i have pushed Vray proxy to the “limit” but this is WOW
here is a render with 2600 onyx trees, each have ~ 250000 poly, and dont mention the others proxys bushes, chairs, umbrellas, boats, yachts, flowers and many more..
Well, the advantage over a script version is that the entire animation is stored in one file; also a velocity channel is stored if you want to do motion blur on the animated proxy later on (either 3d motion blur, or through a velocity channel).
Does that mean that a copy of the mesh is saved per step like the script? Or are just the transforms saved? Is world space position saved or just topology changes?
The .vrmesh file contains snapshots of the mesh for the different frames, so it can handle both deformation and topology changes. Whether the transformation is saved also, depends on the selected export method (as single mesh which includes the transformation, or as separate meshes which does not include the transformation).
Mostly, as large as making a new file for each frame, and then adding them together. This may be quite a lot of data, but there is really no other way around it (storing one file for each frame would be same, diskspace-wise). Of course, the file is never loaded fully into memory, only the chunks that are currently needed for rendering.
Depending on how much time I have before the next official build, I may be adding some compression to the files to reduce the disk space requirements, which should help somewhat.
But a compressed file needs to be decompressed before use, so considering that rendertimes depend strongly on how fast can you access the proxy, it might not be the best thing to do.
Disk access is so slow, that any decompression time is negligible… futher on, since less data needs to be read from the disk, this may actually turn out to be faster…
Should be even better in that case since decompression is done locally on each node. For instance, saving a 100MB Max file over a network is many times faster when that file is compressed since the main bottleneck is the network speed.
I see, didn’t knew how the processing times were related. But than again, what you say is fully logical, so my bad. I’m really happy that you constantly work on the proxies, imo it’s one of VRay’s best features.
