Massive 3D project using GrowFX
Hi All,
Just recently finished a massive 3D project using GrowFX.
At the top of the render you can see all the different trees & plants made for this project.
GrowFX is so versatile that I can easily & quickly produce ANY tree or plant species specified by the client. [Admittedly GrowFX has a steep learning curve but once you understand it the world is at your feet with what you can produce.]
For this project there were 7 different Tree species & 7 different plant species.
GrowFX!!! - I wouldn’t grow with anything else…lol
Kind Regards
Jamie
Nice! If I had to crit I’d say you have too much variety in your green and also the materials could have a more organic look but this being an air shot translucency is a bit tough to achieve.
I’ve been using GrowFX excessively during the last months and hopefully get something finished to show for it. Yeah the learning curve is steep but it’s just so much fun measuring and replicating all kinds of plants :slight_smile: Are those two on the left maple trees? Could you render a close-up?
Hey Jamie, nice image.
We have just been trying to produce some more trees using onyx, with curved “plate” leaves with opacity maped leaves. They are coming out around 3 million polys a tree and are hard to handle until we convert to Vraymesh.
Does grow FX have the ability to have curved leaves, and is the poly count high?
GrowFX allows you to have curved plates, yes, and also you can have as many polys per leaf as you want.
looks good jamie.. can you do a blow-up @ an area with shrubs and flowers? it hard to see @ this res.
Davis
Looks good, but I would like to see something higher res to see the detail too :slight_smile: GrowFx has been in the kit for a few years now and I agree that it is powerful, but I’m still on the bottom leg of that learning curve.
oh my god. This sentence. -1. Nice image.
Update detailed GrowFX images
Hi All,
Thanks for taking the time to have a look
Here is another Image to show some details better.
Bob-cat
Yes 3 Million is way too much…most trees [even large ones] you should be able to keep under 1 million if you are careful.
Getting trees with a good polycount is a technique that is speparate from any particular softwar program. The main thing is getting the right amount of polys on the branches, as leaves you can’t really tweak too much without loosing quality. Most of the poly count ends up in the last brach & twigs so try to keep sides to only 3…and never use stems unless you have a closeup.
I really feel for you using Onyx and trying to have ANY control over what you get. My purchased copy now sits in the cupboard gathering dust. GrowFX can control the amount of sides at the start & finish of a branch so you can start with 6 sides where it is large & visible & finish with only 3 where it is too small & skinny to notice the difference. You can control every last detail of the construction so you can optimize your trees as much as possible to get the best results
Yes GrowFX gives you the ability to have Curved leaves…as well as bent leaves, curled leaves, custom geometry leaves [even animated custom geometry] …basically ANY leaves or anything you can dream up.
The thing that makes GrowFX so awesome and so disliked at the same time is it’s COMPLETE control over EVERYTHING. Having complete control requires a LOT of parameters & a LOT of learning which is why it’s hard to get going at first. Although they have a small tree & plant library compared to Onyx it’s true power is not really utilized until you get to understand the way it works.
GrowFX will soon have a node UI & that may help some get their head around it easier.
To me the biggest difference appart from the complete control is that GrowFX INTERACTS with the Geometry in your scene, something Onyx simply can’t do. GrowFX can grow like ivy generator, in that is fully aware of all the 3D geometry you specify & can change it’s shape depending on a multitude of parameters & modifiers that control interaction.
Come on Moondoggie…that was pure marketing brilliance…[ it was supposed to be my very very dry Australian sense of humor]:grin:
Kind regards
Jamie
i am liking those close ups… i like the way you take you time with the vegetation..
Thanks mate, now that you mention it, I think it is the lack of control that maybe the downside to onyx and why its difficult to get want you want.
Just downloaded the demo, will post back…
Good stuff Jamie!
How long did it take you to make all the trees?
hmmm…it depends on the complexity but anywhere from 10mins to 45 mins. It all depends on how much time you have to devote to it. All tree software requires a certain amount of time to create a nice tree.
Hope this helps
Now sell your aussie trees! I am sure there would be a few sales :slight_smile:
Very nice - thanks for showing the details.
/b
Thanks for the closeups Jamie.
I have been thinking about getting GrowFX too and your trees look promising.
In general, the geometry and structure of the trees look good…however, I find the colours and textures a little oversaturated.
Perhaps a bit more time on getting the materials right would make them much more realistic.
Hi Bob-cat,
here is an example of a very mature tree nicely optimised at approx 1 million Polys. This sort of tree could easily set you back up to 5 million polys if you’re not careful. GrowFX lets you easily control the polygon number & optimize to your hearts content.
Most trees I use in projects [Unless they are for closeup] are between 200,000 to 600,000 & you can make almost any tree look fine with that amount of polys. Remeber you may have to work with many tree & plant species in a scene & keeping things at this level allows you to do 2 variations of each tree species which adds more realism.
The massive scene I did in the renders with all those different tree & plant models [30 unique trees & plants] was only using 4.5 gb of RAM…[and that includes all the other Hi poly proxys like cars etc.
Hope this helps
Nice scene, what kind of render times where you getting with that.
I also see you are from Australia, how does it do Eucalypts, I find it so difficult to make those sort of trees!
@3DMK
Does GrowFX have some sort of seeding feature, so you could build a tree and then change the seed to quickly make variations? Couldnt find anything about that on their site.
Yes you can change the seed easily.
amazin work and great read, thanks for sharing…
you’ve inspired me to download the demo and have a play!
