Has vray anykind of material converter from max standard to vray. I have 3d cars from dosch design and they have alot of ray trace materials and I guess those are heavy for vray cause I get all kinds of errors if I use more than 1 car in my scene. Converter would take away alot of manual work.
What version of Vray are you using? In 1.47.3, if you access your right click menu, you’ll notice on the bottom just below properties, there s is a feature called “convert to vray scene” or something like that. This will take all standard max materials in your scene and convert them over to Vray materials. I’m not sure how well it preserves the original standard material components, but I use this feature alot for converting older scene files very quickly.
Not sure I helped much, but that seems to be a feature alot of folks here havn’t recognized yet.
The material converter was written by http://www.3dzver.ru/main.html unfortunately he hasn’t posted here in over a year and encoded the script so it can’t be modified to work. Maybe if someone contacts him by e-mail…
As someone pointed out, the convert to vray scene feature does all this quite well. The only problem is it doesn’t properly convert transparency settings in a raytrace material to the correct refraction settings in a vray material.
