VRayMtlConverter v1.0b
I present maxscript for converting Standard materials to VRayMtl materials or reverse.
This tool fine works with such types of materials as: VRayMtlWrapper, Blend, Shellac, Composite!
Also takes into account such parameters of materials as: Diffuse, Bump, Opacity, Reflection, Refraction etc.
ATTENTION! Works while only with 1.09.03n (max5) and 1.09.03r (max6) VRay versions!
PS: In the future I want to add in this maxscript an opportunity of converting Raytrace, Brazil, and fRender materials.
Download this maxscript and test it :slight_smile: :
VRayMtlConverter_v10b.rar
thanks a lot 3DZver!!
with the old converter which I used quite a bit, the only issue I had, which wasn’t that big of a deal most of the time…was that once I converted a standard mat that was already applied to an object/s in the scene to a vray mat…it wasn’t applied to the geomentry that it was aplied to when a standard mat…so I had to manually reapply it to that geometry…most of the time that wasn’t a big deal…but in complex scenes when a mat is appied to many objects that are organized by nested groups and layers…that tended to become quite tedious…so I was wondering if with this new version, once a mat is converted it still stays applied…
again great work, and thanks for sharing this…
paul.
Hi cocolas!
I am pleased, that my converter appeared to you is useful.
Good luck to you!
WOW looks great but it doesnt support the new version yet … so i’ll have to wait … great work :wink:
:slight_smile:
Hi 3DZver !
Good news ! Good job !
I 've never used or tested the old one but this one, I will.
Thank you
Gael
3Dver rocks!
3DZver maybe you share the sources of your script for Chaos Group, so they could make working native material converter in 1.5 :))
Great great great great great !!!
Thank you Thank you Thank you !!!
Re: VRayMtlConverter v1.0b
http://www.3dzver.ru/soft/vray/VRayMtlConverter\_v10b.rar
Can’t wait :smile: :smile: :smile:
Hi 3DZver
great work
maybe you should contact vlado, ore vlado should contact you. The build in converter for the upcomming 1.5 could get better from this maybe.
Tom
tks a lot! but how can i remove&instead of the older version?
Remove old file VRayMtlConverter_v10b.mse, unrar VRayMtlConverter_v10b.rar in a your_maxroot_folder/scripts and read the file VRayMtlConverter_info.txt for the further instructions.
I know Vray will produce better results if I use Vray materials, but will I see better results if I simply convert my standard Max materials to Vray Wrapper materials. What does it actually do? I am in middle of a project, and I am tempted to do it, but I want to be assured ti is not going to make my project go wa-wa. i have about 90 materials in the project of which 80 are probably standard Max mats.
Hi Crazy,
Take it from a guy that “wrapped” 100’s of materials thinking they would work with photons (it was a long time ago). :sweat_smile: :slight_smile:
There is no speed benefit from using a wrapper, a wrapper only is useful to control the GI send and recieve values and/or as a matte material.
Hi Crazy,
If you want to count the project in photons - VRayMtlConverter is just that is necessary for you. You will not change all of 90 materials manually?! :shock: :slight_smile: You can not be afraid, given maxscript works stably enough and maximum correct converts Standard materials in VRay-materials. Already very much many have tried this program in the projects and have remained are pleased with result.
Good luck to you!
PS: Standard materials in VRayMtlWrapper I do not work with photons. :!:
