Material Editing & Render Physics
Hello. I’m new to this Enscape family. I’ve been using Enscape for while. Happened to have better results. I’ve some request in terms of Material editing flexibility.
  1. Separate Normal map and Displacement map function. It is technically and visually different what a normal map and displacement map does to a material. Now enscape offers either displacement or normal map to a material. I suggest you to add both functions to a single material. It is helpful for PBR materials.
  2. Displacement maps - Expecting more refined process for displacing bitmap elements. It is also very convenient when high quality textures like RDT(Real displacement Texture) is using in scene. Suggest the developers to work with RDT and obtain realistic displacement.
  3. Imperfections & Dirt - for increasing realism, an option for adding imperfection map or any other additional map that doesn’t interrupt roughness quality of material. Now enscape offer only roughness map which is essential for a material reflection quality.
  4. Mix map - Addition of mix map can be a solution for above problems. Also mix map is very helpful for PBR materials where AO maps are provided. So in each Parameter like Albedo, Reflection, Opacity, Displacement. option for mix map will be a great feature.
  5. Subsurface Scattering - an option for SSS will be great for skin materials. :slight_smile: if it is possible Enscape will be the first real-time render that will use SSS on screen.
  6. Caustic setting - it is technically complex in process. When light hits on complex glass geometry, it should reflect scatter lights in shadows. But it would be a great addition for photorealistic renders.
these suggestions are of long term development I think ^^ . But that will standout this engine from the competition. Expecting a big announcements..
Hope you look forward on this points. Thank You.
Thank you very much - I will forward that all to our developers. Some of these things may actually be implemented anyway with time, the rest will be filed as feature requests on your behalf. :slight_smile:
+1 for imperfections & dirt
+1
Thank you, I’ll forward your feedback.
+100
Forwarded your upvote too, thanks!
+1
Feel free to now also forward your Feedback through our Enscape Public Voting Portal which you can find more info about here. We appreciate the input!
+1
Same to you in case you haven’t already, feel free to forward the upvote/Feedback through our portal! :slight_smile:
