Id thought id post up this problem and solution as you might be affected.
The material editor would basically hang max, with 0 cpu usage and no vray mats loading or loading blank.
turns out the computers ip had changed and the vray license was looking at the wrong address (itself).
running “Program Files\Chaos Group\V-Ray\3dsmax 2008 for x64\setvrlservice.exe” lets you change that.
