Hi
Im not sure if this is a known issue or not but I could not find anything about it so I’ll submit here.
When adding VRay proxys to a renderlayer and add a material override to that layer/collection, VRay proxys ignores the override. I am not sure if its a bug or simply a feature that does not exist.
We are currently using the following:
VRay v6.10.00 from May 15 2023
Maya 2023
Windows 10 Pro
I have submitted a ticket as well where I included an archived scene with a test scene that showcases the issue.
Best regards
/Rickard
Works fine for me. Check if the proxy already has a material override in its settings.
It has no material override in its settings.
Small correction to the original post though. The proxy is reading a vrmesh, not an alembic.
Try adding a Shader override instead of a Material override.
Could you attach a simple scene where the issue is present so we can troubleshoot?
I have already submitted a ticket and attached a scene where I showcase the issue and linked this forum thread in the ticket. But I will attach the same scene to this post in case you don’t have access to the first ticket.
Thanks Aleksander!
debug_v001.mb.zip (1.94 MB)
The proxy does have a material override already set. Go to the proxy > object hierarchy and scroll down to the “bulpPlant_A_shd”. Click on it and remove the override from the menu below. We already know this may be tedious, so we’ve logged an improvement request (internal bug-tracker id: VMAYA-11288 ) for its improvement. I’ll bump its priority.
