I’m following this tutorial, but I can’t get material override to work. I enable it in the settings, as it’s done the video, but noting happens :-/
Does anyone know what can cause this?
Update
I just tried the Interior Lighting QuickStart In this tutorial the override works ok. strange.
Jorgensen
Exterior Lighting QuickStart
I just posted same question in general public, its not working for me either. Any help is appriciated
I posted there because i did not have forum rights until now.
Thank you for reporting this! We will further investigate what is causing it.
As a workaround, you could Revert to Default Render Settings (bottom-right button) and then enable the material override.
