Hello everyone. I was wondering if anyone had ever experienced this. I am trying to make an animation using bongo on a scene that was previously rendered in Vray. Vray is way too slow for this animation (I have a deadline), so I would like to use rhino render to do a lower quality one.
The material settings were made in V-ray, but when i switch on the rhino renderer, the material settings get stuck. I’ve tried to go in and change them through the layer properties (making sure “basic” option is checked rather than “plug-in” and changing each layer’s properties manually.) It saves them, but when I hit render on the rhino toolbar, it still shows up with the Vray materials (I should mention that it does not really show the materials’ textures or bumps, but just the color.)
I’m fairly new to bongo and Vray, but have been using rhino often for about a year. Is there a setting somewhere that I need to change? Thanks so much! ![]()
