I have a wood material in my model that just won’t update to the correct orientation when it is rendered in Enscape. The columns in this model should have the wood running vertically and the beams horizontally. The columns are a different material from the beams, so that’s not the issue. I have looked at the material editor and I can’t find the materials in question there, so that’s not an option. I am stumped. Does it matter that this is a structural material? This renders correctly when I change the settings to realistic in Revit, but Enscape won’t render it correctly.
