The material looks strange on certain PCs
こんにちは、えりです。
数台の PC を持っていますが、そのうちの 1 台で資料が正しく表示されません。
画像を添付しました。
グラフィックと外観を切り替える手順を試しましたが、うまくいきません。
使用は Revit 2019 です。
解決策を知りたいです。
他に提供すべき情報はありますか?
よろしくお願いします。
@eri_1 , thanks a lot for your report, I’m sorry to hear about that.
First of all, are the materials linked correctly on the machine on which they do not display in Enscape? You can check that by briefly taking a rendering with Revit itself (Or switch to the realistic view). If they are all set up accordingly, can you also please send me a screenshot of the material in the appearance tab of the surfaces on which you experience this?
I’ll take the bet it’s your material libaries/assets missing or unreachable on the problem PC… quick test: use Revit’s renderer (lol) and it’ll tell you if there’s missing materials (and which)
(LOL beaten by mere seconds)
Please post all the settings of your material appearance type in Revit.
Are you running on the same visual settings? Some materials will look significantly different between draft and medium
@Demian_Gutberlet
@snowyweston
@phil_read
Thank you for your reply.
I have attached realistic view appearance and appearance tab (floor surface)
The material is linked has been confirmed.
Please continue to check.
material error-3.pdf (6.57 MB)
material error-1.pdf (9.97 MB)
material error-2.pdf (10.8 MB)
It looks like the General Settings>Revit>Material Selection is set to Graphics. Change it back to Appearance.
@phil_read
Hi
Thank you for your reply!
Appearance settings do not reflect the material and look like this.
This is incorrect.
On the Revit side, the material looks correct. (In realistic view)
  1. Please reset your Enscape visual settings back to default. This material settings do not display properly in Enscape please confirm number 2.
  2. It may be that you need to make an additional render path to your custom materials. Here’s how:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/ENU/Revit/files/GUID-1052854D-7286-4806-861C-9D2DD1416ADA-htm.html
@phil_read
Hi
We have updated Enscape to the latest 3.0.
I think the settings are in the default state.
I rebooted it, but the material is not displayed .correctly.
Revit’s render path is already set.
Is there anything else I have overlooked?
(Double-byte characters are not used.)
We are looking forward to hearing from you.
Hey @eri_1 ,
still looks like Enscape is set to read Revits “Graphics” tab, not the “Appearance” tab.
Can you please make sure that setting says “Appearance” in your General Settings / Revit Tab?
