Material Scale between Rhino and Enscape
Completely new to Enscape. First experiments with an existing project has the scale of materials being very different - the materials are much larger in Enscape than they’re set in Rhino. Is there a common factor by which this variation occurs? (ie. can I divide all size numbers by a certain number to convert between one and the other?) On the other hand, is there a way to ensure that they display the same in both applications?
Welcome to our Forum.
Right away, have you been making use of our built-in Material Editor to create and define your materials for Enscape?
Please also ensure that the project scale itself is set to CM (centimeters) ideally.
If neither makes a difference, kindly let me know!
