Material Warning
I am getting 1000’s of material warnings (caused and exception) for a map and I can’t even find that map in my scene. Is there a way to find the bad map? I used the material search button, but nothing is found.
I merged into a new scene and I tried converting all textures into v-ray materials, but still the error.
I found the bad map deep in a material tree. I don’t see anything that would cause it to be a bad map. What should I be looking for that makes this map a bad map?
One way would be to see if he gets any presents for Santa tomorrow… :wink:
it is getting a lump of coal.
What kind of texture is it (e.g. a Bitmap, Noise etc)? Also, what is the exact warning?
I deleted the object that had the material. The object was a lilypad from iCube’s iFlower collection. It would be easier if I send you the file, is that Okay?
Yep, even better if I can reproduce the issue here.
