Hi everybody have a question…its posible to use vray materials for 3DSmax in Vray For Rhino??..if not, there is a way to do it??
Sorry my english.
(In Spanish: Hola a todos, queria preguntaros si es posible utilizar materiales de Vray para 3DS Max en Vray para Rhino, y si no es asi, existe alguna manera de lograrlo??)
Bye, thanks.
Oscar. ![]()
Re: Materials dilema…
Hi Oscar,
maybe you can use the new material editor?
I did not tryout myself, but i think thats the way it works.
greetings
Jonas
No you can’t use vray materials made in max directly in vfr. However we did release a material converter which works from max to export those materials. So if you have max and vfMax then you can move your materials over.
Hi …![]()
i have the same problem…
i have Rhino and now try to make renders in vray plugin
but how to make .mat to vismat, becoast i have no 3DSMAX,
and i never will have it…
so what shuld i do…
1. buy new 3DSMAX
or
2. put the vray render to recycle bin
thx
(why shuld i use vray render for rhino if i ned a 3DSMAX to convert mat. files to .vismat - i thing is better buy 3DSMAX only then both (vray for rhino + 3dsmax)
so for what is the product if i must buy a 3DMAX to have materials,
sorry but render without materials is basic the same like speedy car without gas :))
or it is a joke?
You create your own vismat materials right in the plug-in, or in the material editor.
You can import materials that already come with VrayforRhino, also. Right-click on “scene materials” in the material editor.
Do you have the Vray Instruction Manual? It’s in the download area. So are a bunch of user’s materials that you can download for free.
Hi:)
txh for quick answer,…
i know that i can make my own material in MatEditor,
but i still try looking for program wiht more material library in basic…
its nothing against vfr !!!, but the problem is me…! and my time.
But i still thing, that Vray is one of the most best renders :-[
bye, have nice time, and sorry for my english
