Materials Not Shown in Rendering
I am new to Enscape and just ran into an issue with rendering in Revit. I have two sets of walls, they use the same brick materials, but one is completely in gray color, not seeing the brick at all. I have no idea how to fix this. Please help! I have attached an image. Thank you !
Check the view you start from doesn’t have phase filters active. Typically “Show Complete” is the default that would confirm this. I’m guessing this is the issue due to the building on the right being a different phase from the building on the left.
Also to check is that nothing has been manually painted or applied with a different material. (Don’t think that is the case as someone would have to paint every face)
Yes, you are correct! It is phase issue. Even though the phase filter says “show all”, it didn’t render all until I change it to “Completed Project”.
That makes sense, if you go into the manage phases panel and look at Show All - it still applies the overrides to each phase (New, Existing, Demo, Temp). It just turns them all on at the same time - whereas you would typically only show a few of those together on a plan. Show Complete basically shows only what the project will look like after the phase is complete without any overridden material settings. Glad that fixed it!
