I have an issue with the objects in revit appearing as if they’re glowing. Enscape live view (Image 1) shows them as normal, however, once the image is rendered, the appearance changes completely (Image 2). None of the materials are self-illuminating,
Appreciate any help!
Check if self-illumination has been assigned to the material in the Revit Material editor.
Hello Phil, no, as I mentioned, none of the materials are self-illuminating.. i have also tried setting the ambient light to 0%, as well as introducing a lot of additional artificial light sources to the room, but none of this has solved the problem..
Thanks a lot for your report.
Is there any chance you could send over this particular part of the project for me to have a quick look at? (you can use wetransfer.com for uploads) I think that would be easiest in finding out what this is caused by exactly.
Also, when you turn the time of day to night or reduce the Sun Brightness in the Atmosphere tab of our Visual Settings to 0%, does this still persist? Does this occur in other (perhaps similar) scenes as well?
Last but not least, it can’t hurt to reset your visual settings generally to see if that has any effect on this matter, and to also make sure that you’re using our latest release.
Thank you again in advance!
You’ve added a lot of additional artificial light sources to the room? Is this causing the illumination?
