matte material in vray?
i tried max matte material in vray: i renders correctly, but alpha is always
opaque and shadows don`t affect alpha. what can i do?
thanks
shaggray
Use the matte support in VRay instead, either through VRay properties in the quad menu, or with a VRayMtlWrapper.
hi egz,
i tried what you told me but i dont`get the result i want.
the attached picture shows max`s lighttracer (top)
and vray (bottom) plus both alpha channels…
please, can you tell me what i am doing wrong?
thanks,
shaggray
http://www.mvd.org/beton/hdri\_teapot\_rgba.jpg
Set the matte objects alpha contribution to -1 and turn on shadows and affect alpha
Like this:
Same settings would apply to the VRayMtlWrapper as well.
aaaahhh!
the “alpha contribution” setting was my stumbling block!
Why -1 for alpha contribution? I noticed that changing this between -1 and 0 has no effect.
put something behind the matte object and you will see.
1 gives you a solid alpha
0 gives you a transparent alpha, showing the solid alpha of objects that might be behind it
-1 will mask out objects behind the matte object as well
