Matte Surface Problem
Hello Everyone,
i currently hit an issue while trying to match a 3d Object to a Backplate and HDR Lighting. And there is not one Tutorial that explains it with Vray for Maya.
Well i got this Far:
1. i assigned a Vray Object Properties Node from the Create Menu to the Plane and checked Matte Surface and typed in a Value of -1 for Alpha Contribution (according to the Vray Guide by Fransesco L. ) Everything is good so far. The Plane is not rendered but the Shadow of the Sphere is seen.
http://www.imageshost.de/bilder.php?id=44031fdf57ebfc5a89341d29123c9674
The PROBLEM LEFT is that the Shadow is only on the matte surface plane. But i also need the Shadow of the Spere itself being reflected onto the Sphere.
“Matte for all Secondary Rays” doesn’t help being checked.
P.s. i posted this problem in cgsociety but get links to the Vray Forums, which havent really helped so far. The last one going in the direction is this one:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?68440-Live-Action-and-CG-integration&highlight=live+action
but it doesnt solve the problem with the reflection of the shadow on the object itself.
There is really a need of a video tutorial for this.
Hope that someone can help.
You can try using the “Use background” shader instead.
